- Mon Feb 04, 2008 2:37 pm
#40808
Hy
I've a '93 eg8 (sedan) civic with d15b2 engine (DPFI, jdm, M/T).
The issue is the following:
when the engine is hot, and i'm driving in stop & go traffic, the idle goes crazy. sometimes the it revs at 2000, then I push a little on the pedal, after it drops to 500, or stops. If I turn on a few electical things like heater fan, headlight, rear window heating idle drops to 500. After i press the pedal it goes up to 1300. Otherwise it runs good, but this thing drives me crazy.
I set the idle speed like the manual says several times but it's still bad.
What I already checked: PCV, EACV, Throttle plate, (air filter, fuel filter are new, oil change in jan. 2008)
What else can I check, replace, clean?
Sorry for my poor english, I'll practice....promise
