Civic EG Forum for the Honda Civic EG 1992-1995
DIY: Fix your climate control motor
This forum is locked: you cannot post, reply to, or edit topics.      This topic is locked: you cannot edit posts or make replies.    Civic EG Forum Index -> Interior Interior
View previous topic :: View next topic
Author Message
HiTec
EG Regular
PostPosted: Thu Mar 01, 2012 10:36 am    Post subject: DIY: Fix your climate control motor Reply with quote
While waiting parts, i had to do something useful. I remembered that i had problems with the climate control.
I took some pics while fixing the motor. Hope this DIY is useful to somebody.
Some bird could get a nice nest...:
Fixing the annoying sound motor:
Unscrew the motor from the plastic assembly under the clove box, and unscrew these screws:
Get the rotor out from the axle using some pliers, bench and little hammer:
Use compressed air to blow all those shit off. As you can see in this pic, you cant change the brushes easily, cause there isnĀ“t enough room:
Snap the motor backplate off:
Find a flat metal thingy, put it in a place showed in a picture (watch out the "coils") and carefully hammer the motor out (not completely) from the plastic::
Hammer it so it looks like this. (You can now clean and oil the lower bearing. Oil that "spongebob" looking thing too):
Unclip the plates that hold the brushes and pull the brushes out. Snap out the old ones, and solder in the new brushes (i used the file to modify my alternator brushes to right size): put it all together again and remember to clean and oil the upper bearing:
Use hammer to get the motor back to its plastic assembly, wash all ther parts and put it together and test. Its quiet Wink
Back to top
View user's profile Send private message
teal_dx
The Legend
The Legend
PostPosted: Thu Mar 01, 2012 2:09 pm    Post subject: Reply with quote
Nice DIY! Added to the list thumb up
_________________
Do Not PM me your technical questions. Post them in the forum! thumb up
My 1992 SOHC Turbo Hatch
My Youtube Channel
Back to top
View user's profile Send private message Visit poster's website AIM Address
civic eg-k
EG Regular
PostPosted: Thu Mar 01, 2012 9:51 pm    Post subject: Reply with quote
im doing this next to mine ive been getting some noise from there and it doesnt blow as strong good job thumb up
_________________
my thread
http://civic-eg.com/viewtopic.php?t=23289
Back to top
TrailerTrash
Sr. Member
Sr. Member
PostPosted: Fri Mar 02, 2012 1:06 am    Post subject: Reply with quote
pretty neato! my blower motor doesnt seem to have the power to push hardly any air out of the vents im planning to rip the dash out and see whats up this summer. plus with 290k on it theres bound to be alot of crap down in there.
me and my buddy tore the airbox out of his 325k miles sedan to see why the blower motor wasnt working and we removed, i kid you not, 7lbs of leaves, dirt, and twigs from it. we put it in a bag and weighed it... granted it was all damp and wetish but it was still alot of crap.
heat worked fine after that thumb up
_________________
Back to top
bigpunn421
EG Groupie
EG Groupie
PostPosted: Fri Mar 02, 2012 5:51 am    Post subject: Reply with quote
is this a dash out job? or can i leave it in and remove the glove box?
i wanted to replace my cabin air filter and clean the vents and fan.
_________________
1995 4 door civic b18c jrsc
Back to top
HiTec
EG Regular
PostPosted: Fri Mar 02, 2012 6:37 am    Post subject: Reply with quote
Just remove the glove box, and that little metal plate thats behind it Smile Few bolts and its out.
Back to top
Fada Blayne
EG Groupie
EG Groupie
PostPosted: Fri Mar 02, 2012 8:26 am    Post subject: Reply with quote
Good looks man i'm sure this will come in really handy. Might just do it later today. My first 2 speeds don't work, i'm assuming the contacts in the climate control must be broken. Any ideas how to fix it? Think a new climate control is a must?
_________________
|^^^^^^^^^^^\||____
| The STFU Truck |||""'|""\__,_
| _____________ l||__|__|__|)
Panda Crew Member #24
Coupe Crew #9
Team XXX Racing
Back to top
HiTec
EG Regular
PostPosted: Fri Mar 02, 2012 8:53 am    Post subject: Reply with quote
Thanks!
If your 2 first speed dont work, but the others are fine, you need to check the resistors. If you look at this picture, the resistors are in the upper right corner of the picture, those spring looking parts:
Back to top
TrailerTrash
Sr. Member
Sr. Member
PostPosted: Sat Mar 03, 2012 4:30 am    Post subject: Reply with quote
pretty sure there is no such filter on an eg
_________________
Back to top
Display posts from previous:
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.       Civic EG Forum Index -> Interior All times are GMT
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Protected by Anti-Spam ACP
All trademarks are © their respective owners. Civic-EG.com ©2006. Civic-EG.com is not affiliated with Honda Motor Company, any of its subsidiaries, affiliates, or trademarks.
