Civic EG Forum for the Honda Civic EG 1992-1995
| View previous topic :: View next topic |
| Author |
Message |
teal_dx
The Legend
Posts: 10168 Feedback Score: 9
1992 Honda Civic
Posted: Fri Sep 29, 2006 2:37 pm Post subject: How to determine Bearing size (Main & Rod) |
I am writing this because I had a hard time finding out how to read the stock bearings to figure out what replacements to order from Honda for a D16z6 motor... Maybe this will save somebody some time...
First, Why would you want to do this?
OEM honda bearings are not all the same size, even in the exact same applications.
Honda uses slightly different sized bearings, coded by a number and a color.
Second, why not just buy ACL bearings and call it a day? ACL bearings are good quality, and proven in high HP motors, but they do not come in the different tolerances that the OEM ones are available in.... more of a one size fits all. I went with OEM just for a piece of mind, and will be double checking the clearances with plastigauge of course.
First I want to show this chart I have found on Honda-Tech.com (a great resource for information on all Hondas)
each bearing is coded with a number, and a dab of paint. the paint is on the edge of the bearing, the number is stamped on the crank and rod.
Here is how to read the crank bearings:
[img](I put the red type over the stampings on the crank, they didnt show up well in the pics)
This pic shows where you will get the numbers from for the crank bearings. Also it is important that you NOT mix up the order of your bearings when you take the bottom end of your motor apart! Write it down and label them with a marker- if you get them mixed up, you made a ton more work for yourself.
so from the pic, you can see that bearings from left to right read 3, 2, 3, 3, 2. the "6" that is stamped in the cast area does not matter, only the smaller stamed #'s in the flat parts of the crank matter.
Now after you write those down in order, look at the other half of the bearings for the color.
(click to see ful size image)[/img]
the dab of paint can be hard to see (not visible in pic), it is on the thin edge in the center of the half circle. Also be sure you have your bearings in the right order here, not 180? backwards,
(brown looked more like orange, green was easy to see)
So I need one "Brown 3" bearing two "Brown 2" bearings and two "Green 3" bearings. Go to the parts counter at the dealer and that is what you tell them.
Looking back at the chart, you can see that these are close in size. if one of them was a "Pink 1" I might double check my readings since that is so far from the rest of the bearings.
Rod time:
on the left is the OEM D16z6 rod. Right is Eagle aftermarket rods.
All the OEM roda have a number of 1-4 stamped on them. The number is on one of the edges where the cap meets the rod. All the stock rods had the "2" stamped on them. That is your number for the rod bearing. For finding the color, use the same method as before and look for the dab of paint on the edges of the bearings. Mine were all green.
So if I was going to use these rods again, I would go to the dealer and order a set of four "Green 2" rod bearings.
Since I am using aftermarket rods instead, I need to get the correct size for those.
I did some searching on here and found that the Eagle rods are the equivelant of #3 oem rods for D-series. (they also said B-series are equivelant to #2)
So I would buy four "Green 3" rod bearings.
And that's how to figure out what size OEM bearings to use when re-building your D-series
And double check ALL clearances with plastigauge! |
| Back to top |
teal_dx
The Legend
1992 Honda Civic
Posted: Fri Sep 29, 2006 2:38 pm Post subject: |
UPDATE: So I went to the dealership to order the bearings.... All the Green main bearings were on severe back order, the Browns were discontinued!
Looks like ACL bearings for this D16z6!
I should clarify, The reason I wanted OEM was because I don't have the tools to measure the crank to determine which ACL's to order. After Honda told me there was no way to get the OEM's, I dropped the stripped bottom end off at an engine shop because I didn't have the time or tools to do it myself. ACL's are proven bearings. If I was doing it myself with plastigage, I would have liked to had OEM so I could have a piece of mind that my new bearings were as close to the correct size as possible.
The difference between ACL and OEM is OEM measures them in a single number + a color (easy for people like me who couldn't measure to .0001 of an inch). ACL's must be measured in .0001 of an inch with very precise (and expensive) tools. |
| Back to top |
93civicgsr
Poster
Posts: 73 Feedback Score: 0
Posted: Thu Apr 23, 2009 6:59 pm Post subject: |
| so if i got acl bearings i wouldnt have to worry about oersize or standered sizes? |
| Back to top |
d-mon
EG Groupie
Posts: 541 Feedback Score: 0
Posted: Thu Apr 23, 2009 7:27 pm Post subject: |
i have over 10,000 miles on my ACL bearings, no problems at all.
i did plasti-gauge them to make sure they were within tol. _________________ street machines > dyno queens
| Back to top |
93civicgsr
Poster
Posted: Thu Apr 23, 2009 8:02 pm Post subject: |
| ok so if i had a plasti gauge what would i need to do to determine the correct size? |
| Back to top |
colpitts
EG Regular
Posts: 210 Feedback Score: 0
1993 Honda Civic Si
Posted: Fri Apr 24, 2009 5:16 am Post subject: |
what clearances are you looking for on the rods and mains in an FI motor? i've been told, but forget, and can't find any good info.. im ordering bearings next week and would like to give the motor guys a heads up on what i need so they can tell me what to order. _________________ Fast
Cheap
Reliable
Pick Two, You Can't Have All Three. |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Protected by Anti-Spam ACP
All trademarks are © their respective owners. Civic-EG.com ©2006. Civic-EG.com is not affiliated with Honda Motor Company, any of its subsidiaries, affiliates, or trademarks.
