Civic EG Forum for the Honda Civic EG 1992-1995
The ol b18 swap
Goto page 1, 2  Next
Post new topic      Reply to topic    Civic EG Forum Index -> B Series B Series
View previous topic :: View next topic
Author Message
Boosted_cx
Noobie
PostPosted: Sun Oct 01, 2006 9:54 pm    Post subject: The ol b18 swap Reply with quote
This swap isnt really that hard to do at all!!! all you will need are the following:
Integra motor mounts!!!!
Integra shift linkage
Integra(bseries) axels
and a integra ecu pref. onethat is obd1 since your eg civic is already obd1..otherwise you will have to purchase a conversion harnessfrom either obd0 to obd1 or obd2 to obd1.
This swap really is not that hard at all. All you need to do is undo your harness by the six plugs. three on each side of the motor.
once those are out make sure you have everything disconected and out of your way. ex. exhaust manifold. radiator...etc.
Then what you will want to do is take of your shift linkage and take out your axels.
then what you want to do is just loosen your motor mounts and hook up your chain to using two sterdy mount holes to lift your motor up and out of your car.
Then take out your bolts and begin to lift your motor out of the car (you might need to jock it around a little bit but it will come out.)
The start with you new b series motor and work your way backwards from which you started.
This is a good learning project. If you work on it non stop you should be able to get it done in three to four days.
If you have any questions or comments pm me i check it often.
--Kevin
_________________
Back to top
View user's profile Send private message
eghatch
Poster
PostPosted: Thu Oct 12, 2006 3:22 am    Post subject: Reply with quote
dont forget to disconnect fuel lines and coolant lines Wink
oh and depending on which model and year of car you are swapping the motor into. you may have to wire the vtec solenoid and vtec pressure switch from the ECU to the engine harness!! Wink
just some more good info for anyone who doesnt know
Back to top
View user's profile Send private message Send e-mail MSN Messenger
teal_dx
The Legend
The Legend
PostPosted: Thu Oct 12, 2006 3:33 am    Post subject: Reply with quote
true, only the 92 hatchbacks had the wiring for vtec solenoid & oil pressure sensor ran up to the passenger side shock tower. (correct me if I'm wrong) and the EX/Si had the full wiring & sensors. Any other years and you'll need to pin the wires into your ECU.
Back to top
View user's profile Send private message Visit poster's website AIM Address
eghatch
Poster
PostPosted: Thu Oct 12, 2006 7:05 am    Post subject: Reply with quote
that is true!!
except its weird... im not even sure which model my little brothers car is.. its a 95 4 door... but it had the vtec wiring!! so i stole it off of his car for my b16 swap lol..
Back to top
chnzgoofball
I post x2 & x3 often.
PostPosted: Fri Feb 09, 2007 7:31 pm    Post subject: Reply with quote
thanks a lot for the write up i will be putting this to use in a few weeks im going to pick up an ls in a couple weeks from a buddy so yeah thanks alot
Back to top
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
weaponr82
I dare you to steal my car!
PostPosted: Tue Aug 21, 2007 9:20 pm    Post subject: Reply with quote
Ditto, my next big mod will be a gsr...did honda make an obd1 gsr 1.8 liter? I wanna keep it simple. I was foloowing along until someone said that we had to F with the Vtec wiring. Mines a 94 EX so i should be ok right? I suck with wiring dont ask me to do it please!
Back to top
chnzgoofball
PostPosted: Tue Aug 21, 2007 9:25 pm    Post subject: Reply with quote
there is an obd1 gsr 94-95 integ
_________________
TEAM OUTKAST since AUG 2007
NORCALTUNERS.COM
CIVIC-EG.COM
Back to top
b18crx88
Noobie
PostPosted: Sun Apr 13, 2008 5:06 am    Post subject: great info greatly apreciated Reply with quote
hey guys im new so id like to ask a few questions. this is what i have. obd0 ls block, obd2 ls head, obd2 b16 block. i have read in another forum that i can take the b16 pistons out and put them into the ls block. what i am wondering is if the block i have will work with the head that i have and what i need to do in order to put the b16 pistons into the block. i am curently a member of honda tech and all they seem to do is flame and be all assholes so im hoping that you guys could help me out with some simple yes' and no's thank you!!!!!!
Back to top
teal_dx
The Legend
The Legend
PostPosted: Sun Apr 13, 2008 10:36 pm    Post subject: Reply with quote
I'd start a new thread specifically for your B build thumb up
It probably won't get as much attention in this old B18 swap thread.
_________________
Do Not PM me your technical questions. Post them in the forum! thumb up
1992 SOHC Turbo Hatch
Back to top
egcoupe94
Noobie
PostPosted: Tue Apr 15, 2008 4:08 pm    Post subject: Reply with quote
well im about to swap a b18c1 in to my egcoupe mines a 94 ex should i have any problems or na ?????? Confused
Back to top
shanX
Poster
PostPosted: Sat May 02, 2009 6:00 pm    Post subject: Reply with quote
With a B18C in, would it be difficult to make room for p/s pump and a/c compressor and all?? And could we use/interchange, stuff from D-series, like distributors, starter motors and all for B-series motors?
Back to top
luispizarro25
Noobie
PostPosted: Mon May 11, 2009 11:18 pm    Post subject: Reply with quote
hey guy si know this might be a stupid question and the thread is kinda old but im doing a gsr obd1 into my 93 civic ex coupe. Could you simply and easily explain me what wires i need to play with and how in order to get this engine in my car. I would appreciate the help.
I been looking around but i get all mixed up with the answers.
Thank you
_________________
Back to top
Eg6H2D
Sr. Member
Sr. Member
PostPosted: Sat May 30, 2009 6:52 pm    Post subject: Reply with quote
I got a 93 Si, what exactly would i be looking for? when lookin for the wiring for vtec. I mean it is a D16z6 Vtec, so im hoping it has vtec wiring..
got any pics of it?
Back to top
v8killah
Noobie
PostPosted: Sat Aug 15, 2009 12:39 am    Post subject: Reply with quote
hey yo........i got a few questions i have an lsvtech and i did a swap i took a single cam out and put my ls in an eg and after everything is in the car turned on but it wasnt normal and i took a sencer of the single cam and hooked it up wit the ls. but b4 i pull the ls out of my other eg it didnt have a sencer!!! and i heard something about a cheat sencer to the ecu??????? idk if thats posibble and now the i have the car the car does not run the same it used too and its pissing me off. and i m just tryin to see if i can figure out something b4 i take it in to the shop cuz maybey i can do it my self well if u kinda understand wat i said hit me up that will help alot thanks
Back to top
View user's profile Send private message MSN Messenger
teal_dx
The Legend
The Legend
PostPosted: Sat Aug 15, 2009 1:07 am    Post subject: Reply with quote
I see this is your first post, here's some pointers to help you get a good answer.
1. start a new thread. this is a specific problem and will get more attention if it is not part of an old thread.
2. what do you mean by " wasnt normal" Confused
3. what "sensor" are you talking about?
4. how is it running now compared to before?
5. do you have a check engine light and what is the code? (DIY for checking code in the Electrical section)
thumb up
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic       Civic EG Forum Index -> B Series All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Protected by Anti-Spam ACP
All trademarks are © their respective owners. Civic-EG.com ©2006. Civic-EG.com is not affiliated with Honda Motor Company, any of its subsidiaries, affiliates, or trademarks.
