Civic EG Forum for the Honda Civic EG 1992-1995
Painting your calipers (without a caliper paint kit)
Post new topic      Reply to topic    Civic EG Forum Index -> EG Chassis Brakes EG Chassis Brakes
View previous topic :: View next topic
Author Message
teal_dx
The Legend
The Legend
1992 Honda Civic
PostPosted: Thu Sep 28, 2006 5:39 pm    Post subject: Painting your calipers (without a caliper paint kit) Reply with quote
First, remove the caliper from your vehicle. A good time to do this is when you replace your stock brake lines with stainless steel braided ones, since you will already have to bleed the brakes anyways.
Put something in the hole on the back where the line connects. I used a nut with tape wrapped around the thread a few times to get a snug fit. You don't want any thing getting inside your caliper.
Hose them down with come brake cleaner or something similar. (I had a can of carb cleaner, also works)
If your calipers are 14 years old like mine, they probably still looked like crap rolled in rust chips. There was still surface rust all over that needed to be removed. This is done with a wire brush. You can spend hours scrubbing them with a wire brush, or get a small wire wheel and put it on a drill and be done in 20 minutes.
After you grind them with the wire wheel, they will still be brown, but have a slight shine to them. This is good. Take them out side for another cleaning to remove all the dust and any missed grime.
Then keep them free from grease/dirt and use some Self Etching Primer on them in a few light coats. This will help the paint adhere to the metal. Notice I got lazy and did not tape off the rubber boots. The paint will not stick to the rubber and will fall off over time.
Next paint with your color of choice. Do be sure to use Engine Enamel though, it is made for high temperatures with ceramic in the paint. The 500? will work fine. (The 1200? is a little more expensive, but meant for exhaust.)
Follow the drying directions on the can, waiting about 10 mins in between coats. Waiting too long will allow the Enamel paint to cure and then you'll have to wait a really long time (5 days) before you can add a coat. I put on about 5 thin coats. Then I put on a couple more coats with a clear engine enamel for added protection.
After I got them done, I noticed I should have removed those little clips that hold on the brake pads.... oh well, as long as those clips are there, you won't see the bare spots behind them.
And the final product behind the beater rims:
Be sure to avoid getting any brake fluid on them after painting, that stuff will take the paint off almost like a paint stripper.
Back to top
View user's profile Send private message Visit poster's website AIM Address
solbrothers
Poster
2007 Honda Jazz
PostPosted: Sun Oct 15, 2006 6:03 pm    Post subject: Reply with quote
Nice how-to!! also good choice on the color.
Back to top
View user's profile Send private message Send e-mail Visit poster's website
BAXTER_EJ1
Drives to Ohio for Civic-EG meets!
PostPosted: Fri Oct 19, 2007 10:40 pm    Post subject: Reply with quote
lol "also, if your calipers are 14 year old like mine, they'll still look like shit covered in rust chippings"
I need to do this thumb up
Back to top
View user's profile Send private message MSN Messenger
chnzgoofball
I post x2 & x3 often.
PostPosted: Fri Oct 19, 2007 11:18 pm    Post subject: Reply with quote
never really been a fan of painted calipers...
_________________
TEAM OUTKAST since AUG 2007
NORCALTUNERS.COM
CIVIC-EG.COM
Back to top
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
Greasedmonkey
Hm which Teal Hatch shall I drive today?
1993 Honda Civic Si
PostPosted: Fri Oct 19, 2007 11:33 pm    Post subject: Reply with quote
looks great, but it looks like you need to upgrade to GSR fronts...
_________________
Teal Hatch CultKSport KontrolledCircuit///Hero
Back to top
View user's profile Send private message AIM Address MSN Messenger
LowTEC-Derbo
Turbo Mafia
Turbo Mafia
1993 Honda Civic ex coupe
PostPosted: Sat Oct 20, 2007 2:02 am    Post subject: Reply with quote
nothing wrong with painting rusted calipers to black or silver Smile
_________________
-LowTEC Derbo "the coupe" Build Thread
http://civic-eg.com/viewtopic.php?t=1589
272whp 214wtq
Back to top
york62
Moderator & DIY Master
1993 Honda Civic Si
PostPosted: Sat Oct 20, 2007 3:11 am    Post subject: Reply with quote
this is a great wirte up! i will prolly be doing this this winter.
_________________
Craig
Gorveatt wrote:
*looks at hand* so what do you want to do baby
Back to top
vtec_gloucester
Moderating the UK
Moderating the UK
1992 Honda Civic VTi
PostPosted: Sun Oct 21, 2007 11:21 am    Post subject: Reply with quote
+1
if i ever painted mine they would be black...
another great "how to" thought Teal thumb up
_________________
Back to top
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Vincentex3
Poster
PostPosted: Thu Jan 08, 2009 10:57 pm    Post subject: Reply with quote
I like you choice in color BTW why do you need to use the special paint
Back to top
View user's profile Send private message Send e-mail MSN Messenger
zeppelin101
EG Groupie
EG Groupie
PostPosted: Thu Jan 08, 2009 11:29 pm    Post subject: Reply with quote
You need thermal paint as the brakes get very hot and ordinary paint will just come off as soon you as you heat the caliper up.
_________________
Back to top
teal_dx
The Legend
The Legend
1992 Honda Civic
PostPosted: Fri Jan 09, 2009 3:07 am    Post subject: Reply with quote
yep, the high temp paint has ceramics in the paint to withstand the high heat.
_________________
Do Not PM me your technical questions. Post them in the forum! thumb up
My 1992 SOHC Turbo Hatch Build Thread
Back to top
Display posts from previous:
Post new topic   Reply to topic       Civic EG Forum Index -> EG Chassis Brakes All times are GMT
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
Protected by Anti-Spam ACP
All trademarks are © their respective owners. Civic-EG.com ©2006. Civic-EG.com is not affiliated with Honda Motor Company, any of its subsidiaries, affiliates, or trademarks.
