- Mon Feb 09, 2009 1:33 pm
#95193
I have a 92 eg with the rear disc brake set up, and i think the previous owner didnt swap the porpotioning valve....how can i tell??? other than just looking at it, isnt there some kinda of stamping on it? and i heard that if i dont change it that my brakes will wrap everytime....true??? and i also plan on swapping integra ls suspension, does any 1 know how high it will sit and how comfortable the ride will be?
Graham wrote:suspendedHatch wrote:If you keep your original front brakes, then no. If you swap all four corners, then definitely YES. Otherwise you will lock them up at every quick stop.
Not true - im still running the original prop valve for rear drums and now have 282mm twinpots at the front and rear discs - fronts will lock if you really try but the rears have NEVER locked. The rear calipers are so weak there's no chance they'll lock the wheels.
I also run the original valve and have yet to see problems in my braking.
