- Sat Jan 10, 2009 6:40 am
#88007
i got a high idle checked timing and its right now, checked vacuum lines nothing there unless i have a line in a wrong position anyone have a diagram for vacuum lines? i think it may also be which ill have to check when i get home is idle control valve may be dirty or leak but i think if it had a leak coolent would leak. but confused one the no bottom end, checked the plugs to see if there faulled but were fine. changed fuel filter, air filter, still no bottom end power but once rpms rise got tons of power. put 91 octane thinking fuel was bad in the tank since car sat for about 6-7 weeks at 1/4 tanks. still no power. any other thoughts?
