By sohc ftw
#158676 Does the d15z1 vtece has a lightweight flywheel? If so will it bolt right up to a d16a6?
#158699 not sure about the weight, but the 92-00 uses a slightly larger flywheel/clutch combo than the d16a6 and other obd0 sohc's.
However, I believe that if you change out the clutch, pressure plate and flywheel all together, then you can use a 92-00 clutch/flywheel on a d16a6.
Does anyone know for sure?
By sohc ftw
#158701 thanks for the info bro im not for sure but ive been doing the research and the d15z1 has a 8.5 pound flywheel
#160426 Yes it has a lighter flywheel. It needs to to avoid bogging since it's designed to cruise in the 1000 RPM range.
I don't think it's 8.5 lbs though.
