By jordy478
#175918 what does this code me......electronic load detector ?
#176201 The electronic load detector is a sensor built into your under-hood fuse box that detects when your place a heavy electronic load on the alternator, ie head lights, brights, blower motor. When it detects a heavy load, it adjusts the ignition timing and idle motor to prevent your alternator from stalling your engine, similar to the power steering pressure sensor and the AC idle-up function.
#176202 although the ELD can be removed from bottom of the fuse box, honda does not sell just the ELD, only the whole fuse box. I think only US cars had the ELD, maybe EDM. japanese did not have the ELD.
From experience, there can be other problems in the charging system that will cause the ELD code, such as bad wiring.
Did you do anything recently?
By jordy478
#176339 i did a d16z6 motor swap into a honda civic lx....it seems to have a slight hesitation from time to time .... and it sometimes back fires when shifting gears....but i dont think my valve clearence is right
