By stussy_legend
#249119 right guys, i need some help here. i have got a D15B2 engine on my EG atm, and i got a complete car(del sol) which has a JDM D15B engine in it.
have i got everything i need for the conversion?!
am i correct i can reuse the following parts from my eg:
-Drive Shaft
-Tranny
-Radiator
-Engine Mounts
and the parts i need to transfer are:
-ECU(P08)
-obd1 looms(both engine & interior)
-Egnine(Obviously :P )
i know the distributors are different in both engines, what about all the other pumps?! i just replaced my PS pump recently, can i still reuse it?! Also, does the D15B use the same timing belt/alternater belt,etc... as the Z6?!
i am shit at this thing, and this is my understanding after doing some reading. am i on the right track?!
thx
Ricky
By 707eg6
#249132
stussy_legend wrote:right guys, i need some help here. i have got a D15B2 engine on my EG atm, and i got a complete car(del sol) which has a JDM D15B engine in it.
-Drive Shaft
-Tranny
-Radiator
-Engine Mounts
-ECU(P08)
thx
Ricky
ya you r right but the timing belt wont work from the d15.-Drive Shaft
-Tranny
-Radiator
-Engine Mounts
R OK
By Fada Blayne
#249138 If I'm not mistaken you are going to need a VX timing belt. Or just order the jdm one on eBay
By stussy_legend
#249273 alright, since i am in the UK. i dun get D15Z1(VX) here. but i have found a site to order some belt.....bloody expensive tho....
after a lil disccusion with my mates, i am confused now if i can use the whole wiring loom from the D15B and just plug and play to the ECU, or i would need a converion harnesses?! or esi loom?!
By stussy_legend
#252414 after a longer consideration, i am doing a Mini me instead of the swap. but my only concern is the wiring, can i just swap the whole loom from the D15B(obd1) to my EG(obd0) along with the P08 ECU?!, just plug and play?!
