By tha-shabbster
#259257 Alright I got a d15b7 I have spark and I'm getting fuel bit its not starting I replaced plugs wires distributor it was running before and I turned it off then it wouldn't start back up then I changed everything and its still not starting..
By 92lhdsiconvo
#259392 i am having the same problem with my d16z6. It only happens sometimes though. If you find out what it is please post why it was not starting. I have tried main relay, fuses, plugs, wires, cap, rotor, iac, throttle body and gasket, fuel pressure regulator, the valve on the other end of the fuel rail, and the ecu. None of these things have fixed the problem and i am lost also.
By ghskid06
#259403 You need to do a compression check.
Lhd, it could be your fuel pump going out or faulty wiring.
#259422 Try checking the ICM and Coil inside the Dizzy. U can either test them yourself or take them to a Autoparts store like Autozone or Oriley's and they will test them for free. :thumb:
tha-shabbster wrote:Alright I got a d15b7 I have spark and I'm getting fuel bit its not starting I replaced plugs wires distributor it was running before and I turned it off then it wouldn't start back up then I changed everything and its still not starting..
Is it trying to start at all, like even a little sputter?
I'd double check the firing order first. :thumb:
By 92lhdsiconvo
#259624 if both q's are to me i work at autozone and the car starts and runs perfect most of the time. It just doesnt start sometimes. It runs strong from 600-7700 with no sputtering at all.
By stussy_legend
#260140 check the main relay, i had the same problem b4, car runs fine, everything is fine, just doesnt wanna start up after i turn it off sometimes, replaced it and always start first time
By 92lhdsiconvo
#261396 alright so I have now changed the dizzy and ignition switch still without any luck. I have also gone and changed the injectors. the car floods and wont start, but if i disconnect the injectors(all four) and start the car it starts easily and runs till its out of gas but as soon as I connect the injectors it floods and wont start. WTF?
By dawg316
#261419
stussy_legend wrote:check the main relay, i had the same problem b4, car runs fine, everything is fine, just doesnt wanna start up after i turn it off sometimes, replaced it and always start first time
X2. main relay
By motoxash
#265815 heya basicly my eg is doing exactly the same sparking and fuel is there im about to hit it hard with loads of spare parts ecu main relay dizzy the lot ill let ya know how i get on shortly and wot it was
