- Tue Jul 17, 2007 1:45 pm
#14562
Actually, I just noticed you said Y5 head. If you're considering that head, I'd look for a Y8 instead. The y5 head is vtec-e from the 96-00 civic HX and is different than the z6/y8 vtec heads. The y5 hx motor uses a "lean burn" mode when cruising to get good gas mileage. In lean burn mode, the 4 valve head switches to 3 valve operation with one intake and 2 exhaust valves per cyl.
The y5 also uses a specific ecu, the obd2 P2N, to do all that stuff.
