- Fri Nov 28, 2008 8:27 pm
#80759
I have a B18B in my '93 hatch. No major mods. I changed the heater core last weekend which turned out to be quite the job. Now when driving the car runs strange. I would compare the sound of the engine to a Subaru boxer engine. Slightly more vibration than usual. And no power. When you step on the gas the car is VERY sluggish but sporadically frees up and runs normally for a few seconds, then goes back to being sluggish.
I thought the cat may have collapsed because the symptoms match that but I took it off and that was fine. I also checked vacuum connections and those looked fine. Any ideas?
edit: I made it half way to work last Monday before the problem started. So the car did run ok on Sunday night and Monday for a bit. I'd say a total of 40 miles before the problem started.
