B16, B18, B20
By jdmpipedreamd16
#156252 I need some parts for my b18a1 and was wondering what from b16a jdm not usdm not sure if it matters will fit my 18 like timing belt water pump tb tenitioner intake sensors and the works really thanks
By Dippin_EG
#156283 all the sensors should work, possibly the Timing belt and water pump. dnt know for sure
#156753 if you have the b16a, take these parts
Oil pump
water pump
Pistons
sensors
head w/cams and valvetrain
Intake manifold
Throttle body
Header - if it has one
Tranny
The timing belt will not fit. Dont waste your time trying.
By jdmpipedreamd16
#156961 ok so putting all the parts u listed on the b18 what kind of power should i be putting down? Anything close to the 170hp mark the b16a was putting out? and thanks again for all the friendly help and tips :thumb:
By JUICE
#157043 its possible to get that @ the wheels with a good tuned LS-Vtec. especially with a little high comp with those pistons.
#157253 if done right, and with tuning alot is possible. Ive seen basic ones make 190+
#157628 Basic ls/v making 190+ b16a pistons, shot peened rods, cams...
By jdmpipedreamd16
#158192 ok my orginal question was will the sensors from my 92 jdm (not usdm) 170hp b16a (u know out of the integra xsi :twisted: ) fit on my usdm b18a1?? well i found out that it will NOT fit so i have an issue my icv is bad can i try and clean it or just shell out for a new one??? thanks again!
#158555 IACV you can clean out. they also should swap around. and over from car to car, as long as its the same style.
