B16, B18, B20
By fatcoupe
#185957 ok, so started the b20 del sol swap....the one thing holding me back at the moment is the shift linkage stabilizer... i got the shift linkage to fit, but the stabilizer like doesn't match up...do i need to take the one from the donor (eg coupe) that the b20 was in before and put that in the del sol? and if so do i swap both the linkage and the stabilizer?
By forcefedEG
#186602 del sol linkage is different than an eg... is that what your running into? and b linkage is diff. than a d
By fatcoupe
#187081 yes, i know...i got the bseries shift linkage and stabilizer that was used in the eg coupe..will that fit my del sol?
By jdmsol_kid
#187109 hey man im bout to do this same swap. b20 block b16 head turbo. i need to order a few more parts and get the block but let me know how yours is going.
By forcefedEG
#187184
fatcoupe wrote:yes, i know...i got the bseries shift linkage and stabilizer that was used in the eg coupe..will that fit my del sol?
no i dont think there the same friend.... about 98% sure there diff.
By proj3kt X
#187594 eg shift linkage fits into a del sol but wen ur in 4th gear it looks like ur in neutral the eg linkage is 2 inches shorter than a del sol linkage
By forcefedEG
#187640
proj3kt X wrote:eg shift linkage fits into a del sol but wen ur in 4th gear it looks like ur in neutral the eg linkage is 2 inches shorter than a del sol linkage
yeah i knew the eg linkage was shorter, the delsol linkage is longer, you could extend the linkage your self, a yard near me actually had the whold delsol vtec swap, thats the linkage you need friend :thumb: id try ebay and see what you get....
even if it fits it dosent mean its 100% rite....
hasport and avid make good after market linkage, i got hasport for my hatch...
By B18cDelSlo
#187716 You gotta have del sol linkage, or cut and add 2 inches to eg linkage, I had cut/welded linkage on my car at first, But I then switched to Hasport linkage, cause welded linkage is sketchy.
By egsedanguy
#187718
B18cDelSlo wrote:You gotta have del sol linkage, or cut and add 2 inches to eg linkage, I had cut/welded linkage on my car at first, But I then switched to Hasport linkage, cause welded linkage is sketchy.
so what everyone is sayen is he needs the linkage from a b16 del sol???
the del sol d series linkage wont work right?
By forcefedEG
#187855
B18cDelSlo wrote:Right, it must be b-series del sol linkage.
thank you!
