- Sat Mar 07, 2009 7:52 am
#101161
Bumping this. Would this not be a good set up? Still learning Honda Motors. This is a engine from
https://www.kingmotorsports.com/category.aspx?cat=99 all the way at the bottom
King Motorsports Super B16 Crate Motor
The B16 was the motor that jump started the Honda performance scene. Recently the larger B18, H22, and K-Series have been getting a lot of attention, however the B16 is still a great little powerplant when it is set-up correctly. We've developed a potent package that is a real high RPM screamer perfect for street, strip, or track use. Do you like the sound of 9500rpm and 210whp? This little guy provides a very broad torque curve and amazing top end power.
We highly recommend the use of a Hondata system with this engine. If you need one we will work out a package deal - tuning is key to making this combination work correctly.
Here's the quick list of specs:
B16A Block/Crank Fully Balanced and Blueprinted
GSR Head w/ King Stage IV Port/Polish
13.0:1 Compression Ratio
Wiseco Pistons
Skunk2 Pro2+ Cams
Supertech Springs
Crower Steel Retainers
Wiseco Pistons
Rage Header
Moroso 5.5qt Oil Pan
