- Mon Apr 27, 2009 12:13 am
#113386
so i turn on my car and it has a slow crank but turns on. go on some easy driving around the block then stop for a second. my friend pops the hood for a sec and upon closing it shut the car turned off. i try to start the car and it doesnt tried jumping it still. then we checked for spark no spark no cel and fuel pump turnes on any ideas wat i can be?
- Mon Apr 27, 2009 12:28 am
#113389
Check your ground wires.
- Fri May 01, 2009 4:58 am
#114272
Also check your Battery Wires. I had the postive come loose on me and did simialar things. I touched the wire I heard fans turn back on, Tightened up the wire and all was good.
If it's your main relay going out it will start after cooling down. Mine always did until it went out for good. You can buy a new one from honda for 75bucks or so which is the new design and doesn't have the same problem as the old one, or pick up some at a junkyard and when one gets hot and stops working swap for another one. I did this for a while until I bought a new relay from Honda. Never had a problem with that since.
- Sat May 02, 2009 10:19 am
#114459
Check your Fuel Relay. I had the same problem. And thats what i had as a problem.They cost about 70.00 Dollars and is a common problem after years of use.[/b]
- Sat May 02, 2009 5:50 pm
#114505
He said the fuel pump comes on so it's not the main relay.
Never pay $70 for a main relay when you can just get one from an Integra or at least a 94, 95 Civic!
To the OP, you need to test your ICM and coil. Both are inside the distributer. Both commonly go bad. All you need is a digital voltmeter and a repair manual.
Most every coil and ignitor are interchangeable between different models of hondas as long as they are internal to the distributer.
- Sun May 17, 2009 5:55 pm
#117418
IM the OP i got locked out of the ek978 account. so yea i switched dizzy still have a slow crank car didnt turn on still. didnt get a chance to check for spark. will do that could it be a main relay?
- Sun May 17, 2009 9:33 pm
#117453
so yea i changed my dizzy and problem fixed yesss back on the road
