- Fri Jun 12, 2009 11:06 pm
#122670
Does anyone know if this will require a different wiring harnest from another non-vtech engine?? I have a D series as well but I am not sure of the code i just know its a non-v.. Thanks in advance since i am currently barely getting into the engines.
- Fri Jun 12, 2009 11:20 pm
#122672
your harness should work. as long as ther both non v-tec. i belive a d15 harness will also work on a non v-tec b18 with minor changes.
- Sat Jun 13, 2009 2:49 am
#122703
checking the D series engine spec thread, http://civic-eg.com/viewtopic.php?t=171
It came on the base obd0 civics, which were DPFI instead of MPFI. So this engine will use a different harness than an engine from any us 92-95 civic.
My 1992 SOHC Turbo Hatch
- Wed Jun 17, 2009 9:50 pm
#123730
i know that you'll have to rewire you cooling fan switch cuz on d15b2 its on the back of the block and on 0BD1 and up the swith is on the thermostat housing but other than that it should work cuz no other wires go to the block just keep your intake and exhust mani's
