B16, B18, B20
By misir00
#133488 so im buying a 1990 Integra DA9 with a fresh B18B
and i want to know if i could just do a straight swap with out buying other shift linkages and stuff
i wanna know if everything i need is already there
By 3kkl3sia
#133491
misir00 wrote:so im buying a 1990 Integra DA9 with a fresh B18B
if it has a fresh b18b why are you swapping anything?
By JUICE
#133495
pretty sure he wants to swap it into his EG 8)
#133554 If its going from a DA to an EG, you will still need mounts for a B series into a EG, I.E. DC teg mounts or HASport. DA mounts are different.
By misir00
#133614
damnn straight da9's are nice but too heavy
and plus i love my bubble :lol:
By misir00
#133615
Greasedmonkey wrote:If its going from a DA to an EG, you will still need mounts for a B series into a EG, I.E. DC teg mounts or HASport. DA mounts are different.
okk sounds good
By misir00
#134832 ok so i have a question about this swap
my engine in my eg is vtec-e
if i go from vtec to non vtec, is there anything i should be concerned about?
#134842 so you have a VX? if so, you will need to convert to a 4 wire o2 sensor. your vx just has a one wire.
By misir00
#134845
Greasedmonkey wrote:so you have a VX? if so, you will need to convert to a 4 wire o2 sensor. your vx just has a one wire.
so how do i do that?
By EGOX
#135028 http://hondaswap.com/swap-articles/1-wire-4-wire-o2-conversion-32519/
found it in typing 5 words and one click. many of your basic questions can be answered much quicker on google/search engines.
and also there are millions of "how to swap hondas" "bseries into civic" "eg swap DIY guides" and many other wright ups all over forums and the internet. so do a bit of searching. you will learn so very much in minutes. :thumb:
By suspendedHatch
#135739 One wire???
The VX can have either a normal 4 wire if it's a 93+ CA version, or a 5 wire (7 wire plug) if it's federal or 92 CA. But in the US there are no 1 wire O2 Civics after 92.
But as far as VTEC-E goes; no, you don't have anything to worry about.
