By MG6
#142230 So this is the continue of my other thread I had regarding to the radiator Denso vs etc...
Anyways, so i replaced the upper and lower hose, t-stat, t-stat sensor (the one that turns on the fan), and flush all the coolant/bleed.
Everything is OEM, but the temp gauge never pass half. Let the engine idle for 15-20 mins, and no fan turns on. What is the deal on this issue?
Note:
The upper and lower hose gets hose in 20 mins.
By JUICE
#142235 your sure its not kicking on when you drive? maybe just idle isn't getting it hot enough?? and check all wire connections.
By MG6
#142237 I'm not sure yet during driving after the new replacement part. But will report back.
I did do the paper clip to see if the fan turns on, and it does.
So far, everything is good.
By id3379
#142778 Did you check the rad fan fuse ? This was the problem for me, and sounds like yours
you can test to see if the fan even works by jumping the temp sensor wires
By MG6
#142971 Update:
All are good, the fan turns on.
And yup, test the fan by using the paper clip method before switching out the t-stat sensor.
Thank you All
By id3379
#143196 Np, glad you got it working :thumb:
