By 99cx
#146668 okay my 94 cx stopped starting the other day.
i thought its beacuse of a burnt out fuel pump from running dry
i can still here it prime and im pretty sure its getting a spark.
SOO i decided to bump start it down a hill and it ran fine?
the car turns over great so its not a starter or battery?
what else???
please help, it my daily :o
By PandaHatch
#146669 still did same thing after you bump started it.
By 99cx
#146671 yeah like it started drove it home.. then wouldnt start again.
then bump started it one more time. annnnd still the same thing.
By PandaHatch
#146675 thats pretty wierd. have you checked your timing.
By 99cx
#146679 the timing was fine. i was driving it problem free. how could i check the timing?? other then a timing gun, i dont have one.
#146680 check the conections on the starter
it sounds like to me, that it wont start but when u pop start it, it runs fine
so its has to be your starter :thumb:
By 99cx
#146694 are you sure? because i can sit there and turn it over all day. no problem
ill check anyway tho
thanks
By 99cx
#146720 checked the starter, everything looked good
By PandaHatch
#146776 compression?
By 99cx
#146777 nahhh cause when i didnt bump start it is was runnung great like normal.
all cylinders firing.
By Dippin_EG
#146779 I would check the main fuel relay as well, if its bad, you could do the re-solder trick. If that is good i would think your distributor components are starting to go. (ICM, coil pack)
By 99cx
#146780 okay. where is the main fuel relay? how will i know if its toast?
i dont think i have coil packs? and i think i have spark when i bump start it. ill check my dizzy.
thanks.
By PandaHatch
#146786 thats exactly what my ef did back in fhe day i just remembered...main relay
By 99cx
#146788 ohh okay. well where is it? how to i know if its pooched?
can you tell me more about it?
By PandaHatch
#146791 under drivers side dash if i wasnt on wii hnternnet i would get u pics.
