- Wed Oct 28, 2009 1:53 pm
#153321
okay seeing as almost no one from my country is on here ill tell you guys what im doing /doing. ( i cant hold it in any more)
okay i ran bearings so i thought time to rebuild.
so my plans are as follows.
increase boost, intercooler/aftercooler, build the bottom end, mini me swap.
so as it is now. just had the block honed to 76mm got vitara's to go in there. still waiting for me rings.
doing b18 rods that have been shot peened, get the 2mm bushings made on monday. using a new stock crank. with ACL race bearings.
i have ported and shimmed my oil pump. that takes care of the bottom end. i hope.
going to port match the intake side of the head and step port and polish the exhaust side. still running stock z6 head.
the SC i have pulled apart to port it and get the rotors heat treated. as well s fabricate a charge cooler of sorts to sit between the SC and intake manifold. im also doing a 3.1" nose pully to boost at about 12psi.
i have just imported my P28 from the states and we going to tune it with crome.
will let you know more as i go....
so what you think of that?
Swich: the sound i make as i pass your slow ass
Slow but still in front of you.
Speed Kills...Be Careful...Drive an EG
