By Toneco
#158573 Sup guys I swaped my D15B mani obd1 to a D16y8 obd2 has anybody else done it need to figure out how the Vacuum lines go if there different and sensors also. :?
By Classiccarsrule85
#158579 its not a d15b but if you look at the how-to section on the main forum page (scroll down its there) and i think its teal dx that did a y8 mini me swap or it was a z6 with y8 intake anyhow its a good source look at that and it should help greatly...
By Toneco
#158580 thanks alot bro I will look into that.
By Toneco
#158791 Its a 96-98 looks like the one on your DIY.
i checked it out yesturday and i think i have to drill the hole and buy the tri hose plastic thing.
By Toneco
#158878 Oh kay
should i do the same as your DIY?
#158901 yeah you'll need to or you will have a vacuum leak. plug those 4 tiny holes and then cap off the extra vac lines :thumb:
Also use the IM gasket for the 99-00 y8
By Toneco
#158939 Alright. i will.
I got the normal gasket and it lined up but should i get the 99-00 y8 one?
By Toneco
#159431 my engine is looping while it's idling.
what should i do?
#159482 sounds like you have a vacuum leak, or ait pockets in coolant can cause it too. As well as a dirty IACV, FITV... there's a lot of things.
Usually it is vacuum leak, especially if you just put a new manifold on.
listen for a hissing noise under the hood and find where it is from.
By Toneco
#159488 Hmmm
well wen i found out the i had to do the t splitter and IAT drilled whole i took off the mani and what not but before i did so i turned on the car and it didnt do that. Now its doing it ill tire to find a link.
thanks, teal
By Toneco
#159494 found the link now it revs to 2000 rpms then once i give it gas it drops to 700rpms then back up to 2000rpms.
how can i get rid of air pockets in coolant??
#159543 when engine is cold, take off rad cap.
Start car and let idle until up to normal operating temperature. Thermostat will open, if not give a tiny bit of gas. Keep topping off radiator with coolant when it gets low.
