- Tue Dec 01, 2009 6:29 am
#159271
was anything broken?
id take it back out and reinstall it.
when you take it out.. should be 2 10mm hold the window to the regulator
take out the window completely.
regreease the tracks with lithium grease.
when you grease it make sure the rubber peices on the track are in place and not knocked off.
reinstall window and make sure you slide it in place. and tighten the 2 10's there is a spot where you can access thru the door.(i assume you know this since you already put your window back)
you may need to loosen the 10's that hold the regulator in place to place the window in.
hand tigthen all the bolts and test it.
after satisfaction tighten everything back up
92 civic cx sold!!
white 92 civic Si (traded)
primered 94 teg sold
92 civic DX sold!!
93 red EX coupe parted out!
92 civic LX sold!!
90 240sx sold!
93 faded black EX coupe
