By PandaHatch
#163517 damn bro check if you can roll start if not its a sensor or ground issue i would think hopefully you get this resolved so u can get home post quick and i will help all i can. check pm for my # and call i will try to help.
By ikon
#163518 does it turn over? what does it sound like? have u tried jumping it? maybe its just a bad battery.
By arsenal_408
#163522 Its not the battery,I t does roll start,there's a click and the fuel pump hum
By ikon
#163525 maybe ur filter is clogged up. have u let the tank get low or empty lately? when was the last time u changed it? if it wont stay on after a cold start clean ur iacv and ur fitv on the intake manifold.
By arsenal_408
#163530 So this is wat happen,I drove it to work about 15 mile as soon as I got on the freeway it died,got a push from a tow ruck and it started,arriving to work I was giving it a lil gas so it could hold idle and I let go and it completly died,pushed it agin and it started ,parked it and started it rite back up everything was normal,went a half hour later same started no problem,and know about an hour later same problem won't start
By arsenal_408
#163532 Would it roll start with a bad battery conection
By Classiccarsrule85
#163536
arsenal_408 wrote:Would it roll start with a bad battery conection
it may depends i mean if the alternators good and you pop-start it your getting electricity from that because the motors spinning well....now if its the starter which it may be id tap it or something to see if you could free it up....but this happened to me where the starter was working perfectly fine for a bit then quit on me and yet it also worked here and there before it completely went on me......tapping the starter may not work all the time it just free's it up somewhat....if its possible and you feel ok doing it jump the two terminals on the starter to see if it just clicks or turns the motor over.....if it dose this(since you said your battery was ok) then yea you should be able to see fi your starters ok now make sure its in neutral and the key on when doing this or it wont work.....
By arsenal_408
#163539 Hey thanks,ill try that wen I get home,any other possible things it could be
By arsenal_408
#163595 Thanks guys for the quick responses,ii had replaced the battery,the positive post was to small for the idk wat its called for the positive wire connection,so I put it upside down,it worked fine for a few days,so I made it home safe,turnd off the car,didn't start,so turnd the conection back around left it a lil losse and it started rite up,thanks guys,thanks panda .
By PandaHatch
#163600 no prob man
