By HondaHoe187
#162829 ok im flippin pissed right now cuz i just took off my itm off of my d15 head and am replacing it with a z6 and i found that there is one less coolant line on the z6 what do i do can neone help me? ive read somewhere about bypassing some coolant line on the itm to make ur engine run better for a longer peoriod of time....does ne one know about this and if you do point me in the right dirrection or give me the thread....and if ne one is wondering i got a whole vtec head but i wanted to wait till summer to put the whole heaad on..i painted the itm and i was bored today so i tried to put it on my d15 and now im stuck please help me thanx fellas
By ikon
#162852 wait im running a z6 im on my d15b....... is there something different cuz they looked the same to me.
By HondaHoe187
#162854 Yea if your looking straight at the d15 itm under the front left runner there is a coolant line that runs from there to the bottom of the throttle body and on th z6 that isn't there. But yea I was just so frustrated earlier but this def helps thanx I'll let you know how I make out
By ikon
#162856 hhhmmmm i gotta look under the hood tomorrow cuz im still gettin coolant to my fitv.
#162901 a jdm d15b will be just like a z6, where as the B15b2/7 or what ever will be different.
By ikon
#163049 awesome. thanks for clearing that up. :thumb:
By suspendedHatch
#163234 Run a new hose from that outlet to the nipple that's roughly in the same place on the passenger side. If you follow the line from your IACV it goes there. You can bypass the throttle body and IACV coolant lines and pick up almost as much hp as you get from a CAI.
Just make sure you put a solid gasket between your FITV and throttle body or else you'll have a major vacuum leak. The IACV lines can be left open. In fact you can just remove them via two screws.
By HondaHoe187
#164059 Hey I'm just wondering where I can get the solid gasket from
By HondaHoe187
#166711 ran into another problem today....what is the black thing in the back of the mani....it plugs into the harness....theres a hose on it and there was a port to plug into the old mani and the z6 doesnt have it im wondering if it is even needed to be plugged in to the mani cuz the hole is so small?
#166766 Sounds like you are describing the EVAP Purge Control Solenoid Valve.
You need to have it plugged into the harness or you'll get a CEL, but I think it will still run with the vac lines not going to it. It has a line going to the intake manifold and the other goes to the charcoal canister.
By HondaHoe187
#166932 i think it has one going to the intake mani and to the catch can not the charcoal canister unless that is the charcoal...
By eg84dr
#167472
teal_dx wrote:Sounds like you are describing the EVAP Purge Control Solenoid Valve.
not true
i havnt had mine plugged in for a year now and no CEL
unless your thinking of obd2 cause that will throw a code
b ut obd1 doesnt =]
By HondaHoe187
#169100 ok new problem....i put the mani on and now the car will barely turn over but will......it will stay running but when i hit the gas it dies right out....idles like absolute shit too and throws engine light....as soon as i hit the gas it just sputters and dies....and back to the t hose thing the hose comes out of the block then into my iacv then out and into the thing underneath the throttle body then i spliced tat hose into the other coolant line with a t hose im just wondering if thats right and if not is that my problem....im thinkin maybe i can take all the stuff off the b7 and put it on the z6 and correct this...idk what do you guys think....im just mad cuz now i cant drive my car and i just got the blades :eh: :thumbdown:
