By jordy478
#173027 are all d series distributors tha same? because the one for my old d15b7 and the one for my d16z6 look the same to me?
By intheworks
#173032 i know the plugs are different on certain ones
By ikon
#173052 no they are not the same.
By jordy478
#173053 i kno on mine they match up....but im tryin to figure out y im gettin the crank sensor check light...car was drivin fine then one day went out the blue went into limp mode....ive posted a few times on here and so far i we narrowed it dow to the distributor,wiring harness itself or the ecu
#173057 d16z6, d16z1, jdm b15b all have the same bolt pattern.
D15b7, d16y7, d16y8 all have the same bolt pattern.
OBD2 and obd1 have different plugs.
The d16y5 is different from all other distributors because of extra electronics on the inside.
So no yours will not bolt up to each other's heads properly, but they will plug in to the harness okay.
By suspendedHatch
#173353
teal_dx wrote:The d16y5 is different from all other distributors because of extra electronics on the inside.
Huh?
By Lowkei
#173430
teal_dx wrote:d16z6, d16z1, jdm b15b all have the same bolt pattern.
What he is trying to say was the flux compacitor & the additional ionic neutron copacitors make it different from all the others.... :hehe: jk I have no idea!
What about the VX distributer to the D16z6??
By d-mon
#173843 to answer the original question, the z6 distributor will 'fit' a b7 head but you will never be able to set the ignition timing because the mounting bolt holes don't allow it to rotate far enough.
