Appearance, Paint & Body Work
By Classiccarsrule85
#173779 easiest way isnt always the right or best way.......
easiest way to me and i really am strongly against this way is to pop of th rear emblem and the back part of the tailgate or trunk....place a peice of tape or something to cover up the holes and smear bondo filler over and sand.....i left out a few steps because its the easy way not the right way.....
right way would either be to weld up the holes, or cut out the metal with the holes in it for a peice of sheet metal to the cut hole weld it in bondo up the seams and make it flush then paint...
By BurqueB16
#173803 yeah i remember seeing a neon that had shaved its trunk light and a week later the bondo fell off and left a hole :lol:
bondo = :thumbdown:
#175069 Yup.. just weld them up. Small tacks one at a time so you don't get it too hot and warp anything. Then grind, Sand, Glaze, Primer and Paint it.
By Sire
#176344 When you do it right you should get something like this...
#176347 more examples.. lol
By Claire09
#181777 hey teal_dz did you use bonde or welded a piece of sheet metal?
#182041 You don't have to weld a piece of sheet of metal.. the holes are small enough to just tack them until you fill it in. Bondoing it is just lazy and useless.
Like I said before:
Chance wrote: just weld them up. Small tacks one at a time so you don't get it too hot and warp anything. Then grind, Sand, Glaze, Primer and Paint it.
By Claire09
#183059 oh okay kool...thanks man :thumb:
By egsedanguy
#183188
Chance wrote:You don't have to weld a piece of sheet of metal.. the holes are small enough to just tack them until you fill it in. Bondoing it is just lazy and useless.
Like I said before:
yup just like this. bondo is not a filler. its just suppose to be used as a light coat for smothing out ruffness. not suppose to make bondo thicker than a dime :thumb:
By skateruptown
#183652 i removed mine and welded it shut :) no bondo or cracking in the future, but then that also comes with a new paint job also.
By chilango41
#183660 If you do this. Let me have your H embelem. :D
#183662 Thought you needed a hood emblem?^
By chilango41
#183697 I got it :hehe:
Just taking JdmJin's advice
JdmJin wrote:http://www.amazon.com/Honda-Emblem-White-1-Pc/dp/B001I2MDFO
20$.. but if you reaaaly really want it... or ide hit up the local craigslist.. someones ALWAYS parting out wrecked hondas.. when i had my integra i stockpiled all the acura badges i could get from buying parts.. could get em for like 50 cents.. lol i think i have over 20 of acura ones.. :P
:thumb:
