By AStar59
#179935 i recently did a mini me swap on my 94 eg8 sedan with a d15b7 and recently i noticed the v-tec is not hittin anymore. also the ecu is popin the code 22 for the v-tec pressure sensor. i have already checked all my connections to the sensor and the ecu and they are all good and i have pulled the whole v-tec out and cleaned the ports and the screen and it still isnt workin. do i need to get a new pressure sensor or is there something else i can try?
thanks
By eg84dr
#179942 check oil level
if your even a quart low vtec wont engage
you can check the resitance on the pressure switch not sure what is it but if you have a manual on your civic that will help
By AStar59
#179943 oil level is good just changed it. with mobil 1 10w-30.
ill look up the resitance and check the sensor.
By eg84dr
#179945 http://www.preludeonline.com/f28/help-m ... cs-219712/
that might help not for civics but same concept
if it was me id just go get a new one from a junkyard
they are cheap or you can just pocket it
By forcefedEG
#180611 its probally the pressure sensor... if your on a budget ive heard that the power steering pressure switch will work, there at junk yards and most yards will just let you have them, but i cant 100% copnfirm this that they will work if not you can get one at any parts store i know advanced auto has them for sure...
By 1updelsol
#180815
eg84dr wrote:check oil level
good to know!!!
By forcefedEG
#181591 a boy i used to run with at the track said it would work, they do allmost look identical the power steering is just a litlle bigger... but i have never had to try it... i would like to know for sure if itd work :? but like you said you can pocket it from a yard or they may just let u have it lol :lol:
By forcefedEG
#181807 hell yea let me know how it works out lol :thumb:
By d-mon
#181865 the green connectors for power steering and vtec oil pres. are the same.
