By dro21
#181979 After i turn on my car let it warm up..the revs go down to 100 revs.what can it be.sorry if i sound liek a noob
By MG6
#182079 did you recently change something? more detail please.
By chilango41
#182090 Maybe flush your coolant.
By eg84dr
#182171 more info would be great
such as
what engine? what have you done to it? what did you recently change?
then i bet someone will be able to help you out?
By Dippin_EG
#182206 the first line on the tach indicates 500 rpm.. i dont think your idling at 100 rpm... that sound unreasonable.
By dro21
#182211
Dippin_EG wrote:the first line on the tach indicates 500 rpm.. i dont think your idling at 100 rpm... that sound unreasonable.
Mofo told me it was idling at 100 but whatever.......its a d15z6 cars always since i bought it but recently i changed the oil and spark plugs ever since then the revs are much lower
By ikon
#182230 Low coolant is a common cause. Have u tried adjusting the idle with the adjustment screw on the throttle body? After that try cleaning the idle air control valve and the fast idle thermal valve. Start with the coolant and iacv.
:thumb:
By dro21
#182363
ikon wrote:Low coolant is a common cause. Have u tried adjusting the idle with the adjustment screw on the throttle body? After that try cleaning the idle air control valve and the fast idle thermal valve. Start with the coolant and iacv.
:thumb:
Ill try that tommarow...ill keep you guys posted.
By dro21
#182441 can some1 tell me which1's the iacv and the thermal valve
(pic does not belong to me)
By Eg6H2D
#182480
dro21 wrote:can some1 tell me which1's the iacv and the thermal valve
the iacv is the large piece behind the intake manifold has a black canister attached to it pointng towards the driver side with a plug connected to it. the thermarl fast idle valve is the part connected to the bottom of the throttle body ull see the black coolant hose going into it in this picture right under the throttle plate. i had to replace both a few months back because i was having a 2500rpm idle issue. changed those and bam went away. now from time to time my idle drops to about 500 and then back up to about 800. i have no clue what it is either.. and my idle screw doesnt turn anymore.. :-(
By Eg6H2D
#182481 mentioning the idle screw, which way should u turn to RAISE and which way to Lower the idle?? ????
By suspendedHatch
#182525 If it's never been adjusted, then you shouldn't mess with it. But loosen allows more air.
Remove the IACV and clean out the screens with some carb cleaner. Check your ignition timing. Then reset the ECU.
If that doesn't fix it then your FITV could be stuck closed.
My guess is that your idle is too low during start up. When the engine is cold, it's supposed to idle high around 1100 RPM. Then when you reach operating temp it drops to 750. But yours is probably around 800 when cold and then dropping to 450 which is just about the minimum the engine will idle at.
There are dozens of Civic / Integra idle write-ups throughout the internet. It's a very common problem.
By dro21
#182532
suspendedHatch wrote:If it's never been adjusted, then you shouldn't mess with it. But loosen allows more air.
Actually when its cold it idles at 1000 when its warm its when the idle is very low idle
