- Tue Mar 30, 2010 8:00 pm
#184661
first off no ther is no way to prevent it from cracking. bondo is not to be used like that. if its to thick it just cracks. its designed to smooth out body repairs, not for molding....
second, the way to tak the pc of is to remove the dashboard. its held in by like 8-10 screws. you can do what most ppl do, brake the old one off and were you would srew it in, you would rather use a high strngth apoxi and glue it back on. that what i did.
RSuave wrote:It there a way to prevent it from cracking? Also maybe you can help me out with another issue. The trim that goes around my stereo, there is a piece cracked off and I have no idea how to replace that piece. Any description how to. I found the piece in junyards but had no idea how to get it off. It is around the radio and ac and heat controls then goes across the steering wheel.
