B16, B18, B20
By jdm
#185694 So far I only have the block the pistons rods, oilpan gurdle, gsr water pump, crank shaft, side motor mount tranny mount. This is an b16a block obdo block and I wanna use a b16a obd1 head so what señora would I need. This is my first time messing with b-series motors.lol
#185711 I'm gonna move this to the B series section.
Also check out the DIY list:
http://civic-eg.com/viewtopic.php?t=1474 and click on
"B18c swap by JDM-Chick " :thumb:
By forcefedEG
#185817 any b series vtec head would work... but the b16 head would be your best choice... as far as the generation of the head that dosent matter.
as far as what you need, quite frankly... you need alot...
axles, halfshaft, ecu, shift linkage, if your engines tore down you need a full gasket set. throttle body, not to mention a transmisson, mounts, possibly intake manifold and exhaust manifold, wiring, most all the sensors will work off of a sohc motor assuming you have all that i.e (idle air valve, intake temp. snesor, map, coolant sensors, ect.) also starter, alternator, distributor and much more misc. things... pieceing together a swap from scratch is probally the hardest way to go for you first b swap, but you will figure it out from experience, wich is the best way :thumb: and its a common swap so you can deff. come here for alot of the help..
http://www.fjdistributors.com they have good prices on engine internals (high compression kits) :thumb:
as far as the other stuff check ebay, craigslist, or even this forum :thumb:
