By TrailerTrash
#190080 Would it be safe to assume simply slapping some ZC pistons in a D16a6 would make 12 to 1 compression? or more importantly would it even work? my buddy wants to rebuild the a6 with a slightly built head and put ZC pistons in it and have 12 to 1 compression.
what you guys think?
By jerez.com
#190085 yes you can put zc pistons on a6 block
im runing thee same set up with y8 head no problems at all
you need good tuning and 91 octane gas
By TrailerTrash
#190088 okay sweet thanks guys :woot:
By AutoXCivic
#190110
chrono404 wrote:http://www.zealautowerks.com/dseries.html
This is a compression calc so you see what your compression will be with different piston/head combos. Pretty cool. Should be useful.
It also tells you if the pistons will be above or below the deck ... which is also nice.
By eghatch21
#190222 i have a d15 block wit a y8 head n i wanna run p29 pistons so those pistons wont hit the valves in the head n ruin them?
By forcefedEG
#190379
eghatch21 wrote:i have a d15 block wit a y8 head n i wanna run p29 pistons so those pistons wont hit the valves in the head n ruin them?
dont threadjack start your own thered :thumb:
