B16, B18, B20
By 92dxeg
#193355 Ok guys i just picked up my new motor yesterday its a obd 2 gsr with a b16 type r head on it. it have no dizzy on it would i be able to use a obd1 b16 dizzy on it or do i need an obd2 dizzy for it pics will be up sooon
By forcefedEG
#193359 both will bolt up fine, but you will need an adapter to run an obd2 dist if your using an obd1 engine harness...
http://www.jegs.com/i/MSD+Ignition/121/8864/10551/-1 <- like this one
personally id just get an obd1 dist if you can get your hands on one cheap, if you get a good price on a obd2 and the harness isnt that much more, go that route.... there is no performance difference between the two...
By 92dxeg
#193537 is that all i will need also i got the car with no fuel injectors can i use the ones out of my ls. also is there any thing else that i need obd1 to make it run
By forcefedEG
#193538 yea all the injectors odb1 and 2 were the same size with the exception of the h and f series... and obd1 and 2 having diff. clips... assuming a distributor is all you need, than yes you should be fine...
