B16, B18, B20
By i8umup
#202449 hey guys i have a question i have never done a bseries swap i only messed with the h22 so.... basicly the engine i have now the knock sensor is broken im going to replace but beside the oil filter is a big brass looking solonid. i assume that it is the oil pressure switch is this factory cause i have never seen one that look like this http://www.extremepsi.com/store/images//t_21194.jpg
and the harness that came with this car was lengthend like 5 feet for a wire tuck. i can use the d16z6 harness to run this right or do i need the harness off of a b18c? as far as that picture goes if thats not factory does anyone have a factory part number for a oil pressure sensor?
By fallbacdun
#203381 ok if i am thinking of this correctly that brass thing is so you can hook up your oil guage inside the car could be mistaken tho.... as far as the harnes I just used my b18c harness and a p28 only thing I had to wire up was vtec being a have a cx...hiope this helps
By Eg6H2D
