- Fri Jul 30, 2010 2:59 am
#206736
I'm really considering doing this Fully built, Would I be expecting low comp Pistons etc. like a turbo or its somewhat different? I've seen a procharger LsV but idk build stat? Anyone wanna Chime in go for it show me your knowledge. TIA
- Fri Jul 30, 2010 3:17 am
#206737
I would use the jrsc with yor lsv built to average compression say like 10.5:1 with reliable parts and slap the jrsc on at stock boost. No point to buy low comp pistons the the jrsc can't boost high enought to need them if I'm correct. Someome correct me if I'm wrong
- Fri Jul 30, 2010 3:55 am
#206746
I mentioned that bcuz someone told me so and I was like HUH? since when lol fosho stock boost is around 6-8 psi right?, and 10psi is the other kit im doing a P72 head everything that can be ported, ported even JRSC, I still need the right pully belt tho havent found which one does the job.
93hatcheg wrote:I would use the jrsc with yor lsv built to average compression say like 10.5:1 with reliable parts and slap the jrsc on at stock boost. No point to buy low comp pistons the the jrsc can't boost high enought to need them if I'm correct. Someome correct me if I'm wrong
