By Honda4life
#228007 You could have a bad head gasket which in this case your oil and antifreeze could be mixing. Also you could have bad valve guides or valves. I would check you coolent level or even do a leak leak down. Also as far as the valve guides go, since your car has been sitting awhile they could have gone bad from rust. Hope this narrows it down or pin points the problem.
