- Sun Sep 02, 2007 1:27 pm
#21985
*Wipes dust of thread*
I agree, a mini-me is fairly easy to do.
Only thing is the costs of it.
In Holland, it would set you back 600 euro if you want to do it the right way...
But chances are it'll take a lot of oil.
An engine builds up tension between shortblock and head, because of several reasons.
The minute you take the old head of, tension is released and the shortblock is slightly deformed, causing oilconsumption when you put the head back on.
So if you don't want to spend all that money, especially when trying to save up for a B/H/K series, this is the way to go.
But the reason I got this thread up;
after some research, I came to the conclusion that an adjustable camgear is NOT needed, it's only for the looks on this set-up.
Adj. camgears are (in short) only needed when you buy (a) certain aftermarket camshaft(s).
These are often regrinded OEM cams, so (I don't know what it's called best in English...) point zero has moved, causing your valves making love to the pistons... not nice.
You can correct this with adj. camgears, but when just using a stock cam, or a cam grinded to specs from a blank cam, not nescesary.
The extra horsepower you gain is because of changing the ignition timing.
It is better to control this from within the ECU.
So you can save more money by NOT buying an adj. camgear.
