#231091 well on some models the map sensor was on the firewall and there was a vaccum line from the throttle body to the map
and then some were just screwed on the throttle body
so it depends
and i figured you would need the ecu
and i cant see the damages
By eg84dr
#231219 automatics have the map sensor on the firewall
and 5spds have it on the throttle body
if you get a shipping rate ill sell you my b7 head for next to nothing
send me a pm with shipping info and i can figure it out if you want
By pandapoo4u
#232143 its not you those pistons are exteremely clean the one on the left is spotless[its the one that blew the gasket and the rest are barely coated i can wipe it off
By eg84dr
#232147 looks like its been leaking for a long time if the piston is that clean
also thats the first time iv ever seen a valve stuck in the head do to rust lol
:thumb:
i sold that head too sorry man
you should do a mini me :thumb:
By pandapoo4u
#232150
eg84dr wrote:looks like its been leaking for a long time if the piston is that clean
:thumb:
i found a head to do the mini me but there is too much stuff that i would need for the mini me swap
i already have a head kit for a b7 and i already have the head for the b7 swap all i need is the rocker arms
and i have the b8 valve cover so it will make people think twice bout how slow it is...
and besides i am going to use it as a dd and i need it done asap
i get paid on the 15th and will be able to go junk yard hopping to find my rocker arms ecu and radiator
By pandapoo4u
#232153
eg84dr wrote:nice soundslike you got it all figured out good luck
did you get a metal hedgasket?
i got the felpro head gasket kit from advance auto so i dont think it is
By pandapoo4u
#232154 nope looked it up.. this is what i got
16 valve engine; PermaDry® molded rubber valve cover gskt. incl.; Premium valve stem seals incl
