By eg84dr
#235590
pandapoo4u wrote:so... i feel realllllly dumb... but yet i figured it out i had the tps and map sensor plugs reversed
runs amazingly smooth now
happens to almost evryone that has done a head swap on the d seris
By pandapoo4u
#235625 ok so out of nowhere i have yet another problem and it came out of left field
when i push the gas it dies instantly but its still getting fuel because it will hold a steady idle
if i slowly add gas it will rev all the way but a sudden jump kills the motor instantly i checked the timing belt its fine moved the dizzy all around made no difference
anyone had this problem? have any idea how to fix it?
By Honda4life
#235710 I know you said you checked the timing belt and moved the dizzy around, but also your timing could still be off because the head and block are different so to make up for the difference in timing you mite need an adjustable cam gear. I needed one wen I did my mini me swap. Also check your fuel lines.
By Honda4life
#235711 Also check all sensors. Maybe the ecu?
By pandapoo4u
#235735 Ok its getting fuel because it starts and idles im going to replace the filter it may be clogged...
I am not throwing any cel codes or I could check that
And it worked fine for the first day I drove it just fine up and down the block
As for timing the b7 and b8 are the same the only difference is the extra valves
Not bogging at full throttle
at 1/8 throttle it slowly rises and will redline
At 1/4 throttle or more it just stops like I turned the car off its not a bog or a shutter just a straight shut off
Im thinking it could be a bad tps clogged fuel line that when it adds pressure it gets stopped up it may even be my fuel pump not pushing hard enough im going to go through it all piece by piece it may even be my fpr I have to pull it off and clean it as well
Could the fuel pump relay be going out or would that cause it to not start alltogether...
By pandapoo4u
#236141 ok so little issues solved replaced the tps mad no difference only threw code for the map sensor
so i switched the map and tps plugs again and back to the no idle till its warm but it drives... and once its warm its fine no issues
hummm...
