- Sun Sep 25, 2011 10:02 pm
#274426
I have a 98 b18b i just want to make sure u blled the coolant just by removing the cap on the radiator and make it run until all bubles are out and you keep adding coolant until full?
- Mon Sep 26, 2011 1:15 am
#274438
Let your car get warm, turn the coolant bleeder screw to let the air out, and as soon as coolant starts to come out in a steady stream then close the bleeder screw.
- Mon Sep 26, 2011 2:08 am
#274460
Follow the upper radiator hose to the thermostat housing, it will be on there.
- Mon Sep 26, 2011 2:19 am
#274464
if you cant figure it out after seeing this picture, then you need to take it to a mechanic
it looks like this, but with a radiator hose on it:
- Mon Sep 26, 2011 2:46 am
#274469
no. There should be a bleeder screw on the housing. Looks like a nipple with a hole in the middle of it. That is what you open.
civic15 wrote:ok yeah i think i know where that is but do i loosen the same bolt thats on the picture ?
- Mon Sep 26, 2011 4:39 am
#274491
I have heard of some not having them. In this case, fill up radiator, start car with radiator cap off, turn heater on max heat, let it run through 2 cooling fan cycles(on and off twice), then top off the radiator and you are good to go!
- Mon Sep 26, 2011 4:40 pm
#274547
Take off the radiator cap, start the car warm is up. Put in coolant/water as needed.
There is special tool that helps you do this, makes it really easy.
1986 Nissan 300zx
1980 Kawasaki KZ650
2014 Kawasaki Ninja 300
1980 Kawasaki KZ650
- Mon Sep 26, 2011 7:33 pm
#274605
x2 agrees with last 2 posts
|^^^^^^^^^^^\||____
| The STFU Truck |||""'|""\__,_
| _____________ l||__|__|__|)
Panda Crew Member #24
Coupe Crew #9
Team XXX Racing
Coupe Crew #9
Team XXX Racing
