- Mon Oct 03, 2011 3:15 pm
#275929
alright so i got a d15z1 i jus swapped and evrything to my knowledge is hooked up and it should start but jus cranks over no backfire or sputter. all fuses are hood, main relay is good, thermostat ground is on and the only CEL is for the vtec solenoid cuz its not wired yet. the fuel rail is prmimg and i jus put a new dizzy on it and its getting good spark..did not do a compression test yet but i will soon. if you guys can help me out that would be great, it might just be something stupid i missed... any ideas?? Thanks guys! civic-eg<3
- Mon Oct 03, 2011 10:54 pm
#276037
did a compression test and its 150 at every cylinder..i noticed the plug wires onbthe dizzy werent in the right spots so i switched them and tried and got a little sputter but then nothing. still confused and lost..please help!
- Tue Oct 04, 2011 2:03 am
#276063
double check your physical timing marks.
- Wed Oct 05, 2011 3:48 am
#276282
yup that was it. i checked the timing and redid it all and it started right up. thanks for the help! now i jus need to wire vtec. any suggestions on to wirein vtec into my stock harness? for that clean look.
