- Sat Nov 05, 2011 3:06 pm
#280244
I got my 40/40 off a 91 integra... and the prop valve distribute the braking force... so a 40/40 valve will send more force to the rear then a 60/30 used with drums... but no matter Wat u have the front WILL always do most of the braking.. about 85% of it... its recommended to run a 40/40 so the rear disc will work better then it would wit a stock prop valve...
And you wont really see much of a braking increase.. the major thing rear disc are used for are cooling and weight... like mentioned the front does 85% of the braking no matter what your set up maybe
