- Sun Nov 13, 2011 1:34 am
#281237
Hello everyone,
My name is Ray
I just bought a 1995 civic with 215000 km , new timing belt and radiator.
From the test drive it seems fine, so after the purchase I took the car for a 2500km trip.
When the car drives on the high way(100-120km/hour) outside temp is about 0 degree(Canada), everything is fine, but when it off the highway, stops, or idle, or slow traffic, some time even 60km/h, it gonna overheat
So I check the coolant, shows low.
Because it is a civic cx model so no ac, cold start, after 5 mins, water temp got normal level, but cooling fan still wont turn on.
then take for a test drive for 5 mins, everything is fine, but fan still wont be on.
So my question is, from all the symptoms, do you think
1 need a new thermostat.
2 cooling fan may broken
3 may just a simple coolant flush will do?
4 or because of the thermostat broken so the fan wont be on ?
Or what do you think
I am on really tight budget now, so I am trying to save every penny as possible
Thanks a lot, and please help
My name is Ray
