- Mon Mar 26, 2012 2:09 am
#299806
I've searched this website along with google with the answer to my problem. I have a d15b7 bottom end, d16z6 top end that was put together when I got the car. The car jumps rpms (1500 up to 2000 then drop down to 1500 and repeat over and over) like the IACV is bad but I have taken that out and cleaned it with no fix to my problem. The only time the car does not do it is when the it is at normal temp and the clutch it pushed in. If the clutch is released it will jump weather its warm or cold. Anyone help me?
never heard of the clutch pedal affecting idle like that
any more details?
you could check for a vaccum leak with carb cleaner/starter fluid. spray it all over everything rubber when the car is running and listen for the engine to surge.
my buddy had a very similar problem turned out to be a bad throttle body gasket
