- Sat Dec 08, 2007 10:11 pm
#32806
what make this engine so different from the other D-Series VTEC engines?
anyone?
anyone?
42city-mpg/48highway-mpg....sweet
suspendedHatch wrote:Well, the intake tube and throttle body are tiny for starters. The CX/VX tranny has very long gearing. The engine is designed/tuned to run lean w/out misfiring, especially during cruise. The ECU uses a wideband O2 to be able to detect a lean mixture accurately. It has EGR. It's the only D-series engine that came with a lightweight aluminum alternator mount and front lower driver's side engine mount (bolts up to any D series). And most notably, it uses VTEC-E which is a mechanism that switches from 12 valve mode to 16 valve at 2500 RPM.
Basically Honda wanted a CX with even better gas mileage that would take off from a stop with as much guts as an Si (but it falls flat on it's face around 5500 RPM).
hondajunkee wrote:suspendedHatch wrote:Well, the intake tube and throttle body are tiny for starters. The CX/VX tranny has very long gearing. The engine is designed/tuned to run lean w/out misfiring, especially during cruise. The ECU uses a wideband O2 to be able to detect a lean mixture accurately. It has EGR. It's the only D-series engine that came with a lightweight aluminum alternator mount and front lower driver's side engine mount (bolts up to any D series). And most notably, it uses VTEC-E which is a mechanism that switches from 12 valve mode to 16 valve at 2500 RPM.
^^^ yep, and there the coolest hatch imo, oh also it uses a roller rocker head unlike the other eg's
