- Thu Apr 17, 2014 12:48 pm
#344689
The fan should turn on even if the compressor is not running it activates with the ac switch. When I had my 4 door my ac compressor didn't work but when my car would start over heating I would turn on my ac switch to turn on the ac fan on and that would cool down my car.
- Tue Apr 22, 2014 1:07 am
#344872
Its coming along slow but steady , found out that overt half of my fuses are the wrong amperage for the specific spot so I'll be fixing that soon and I found why my fan wasn't coming on, it was a wire that is broken at the clip where it connects so when I fix that I'll check if the compressor is working properly and start all over......
- Fri Apr 25, 2014 3:20 pm
#345026
OK so I fixed up the fan it comes on every time but still not getting cold what should I look at next? The valve that opens and close(for hot vs cold) its fine I can see the metal wire move under the hood opening and closing, it has freon, blower comes on, fan comes on idk what to check next
- Fri Apr 25, 2014 4:31 pm
#345030
Remember you can't introduce air into the system.
How much freon did you put in your system?
94' civic si
JDM B16A w/AC
My daily driver: http://tiny.cc/3bdut
K3 GSXR 1000: http://tinyurl.com/3u6obdx
JDM B16A w/AC
- Fri Apr 25, 2014 7:40 pm
#345032
Close to 24 oz it didn't take the 2nd bottle completely and what do u mean exactly by introducing air in the system? When I put the freon in it said to purge the line but the gauges I had didn't seem to have that so I hooked the freon can to it let it come out for a few seconds the plug it to the low port to fill it.
How do I test if the compressor is working? What do I need to test it?
- Mon Apr 28, 2014 11:47 pm
#345138
you got to check if the clutch engages and spins the compressor. When its working you will see the high side pressure go up around 150-200 and the low side around 40
jedrick wrote:Close to 24 oz it didn't take the 2nd bottle completely and what do u mean exactly by introducing air in the system? When I put the freon in it said to purge the line but the gauges I had didn't seem to have that so I hooked the freon can to it let it come out for a few seconds the plug it to the low port to fill it.
94' civic si
JDM B16A w/AC
JDM B16A w/AC
- Mon Apr 28, 2014 11:49 pm
#345139
you did the purge right and that's what i was talking about.
94' civic si
JDM B16A w/AC
JDM B16A w/AC
- Fri May 02, 2014 1:35 am
#345244
The outer end of the compressor when not working won't be spinning with the belt. When on the outer end will move with the belt
jedrick wrote:If the pully on the compressor is spinning the belt, does that mean is working? Gonna get the gauges again soon waiting for them to get returned to autozone
94' civic si
JDM B16A w/AC
JDM B16A w/AC
- Page 3 of 4
- 1
- 2
- 3
- 4
