- Wed Jul 29, 2015 2:26 pm
#355029
That is correct 2 step is not anti-lag.
I'll break it down a little more since I have some free time. There isn't anything complicated to explain about a 2-step launch rev-limiter. The true antilag stuff has all sorts of stuff you can look up. I gave some basic explanations of why people say its bad for turbochargers and valves. You can look up all the stuff on secondary air injections and throttle bypass systems if you find yourself wanting to know more.
2-step rev-limiter:
Typically used for launch control on N/A cars. It is a second low end rev-limiter that is set in your engine management. It usually turns off a set mph or can be activated-deactivated by a switch. This is a driving aid to help get consistent launches.
Video of a Civic with a regular 2-step.
https://www.youtube.com/watch?v=AdH6MElplKA
Burn out rev limiter:
A lot of drag racing guys add a 3rd rev limiter activated by a switch to limit RPMs while doing their burnout before each pass. Its just less things for the driver to worry about to get consistent burnouts.
SFWD Honda dragster doing a burnout. Probably using some time of burnout rev limiter.
https://www.youtube.com/watch?v=KGPHxKhcH24
2 step antilag/launch control:
Operates the same way as your standard 2 step system but has additional parameters to adjust timing and fuel. With added fuel and retarded ignition timing the engine allows heated exhaust gasses to leave the engine by simulating load. This spools your turbo before launching. When used properly it is a great tool for drag racers to have consistent launches and no 'lag'. This can generate a lot of heat in the exhaust side of a turbo charger. If you don't know what you are doing or it is used excessively it can build up enough heat to cause damage to the turbo charger or engine.
Supra using 2-step antilag to launch/ roast the tires down the street
https://www.youtube.com/watch?v=TAAvTplSzJE
Antilag
There are multiple type of anti-lag. But the general idea is they keep air and heat moving through the turbocharger to keep boost up between shifts and while off throttle in rally cars so there is a less noticeable lag under those conditions and more immediate power when getting back on the throttle. These Rally style antilag systems can overspool turbochargers exceeding their mechanical limits and they also have the head issues listed in the above launch control antilag.
Watch until the white EVO slows into the corner that popping/backfiring is the rally style antilag. Probably a secondary air injection system.
https://www.youtube.com/watch?v=gCjubttEvWo
Reviving Classic, Crafting Culture.
Classic Honda apparel, prints, and digital downloads.
Instagram:
https://instagram.com/enjoymotorsportsWebsite:
https://enjoymotorsports.com
