By KRYSTED9354
#42720 also should i use the injectors from the vx engine or from the d16a6 engine or the oney from the d16z6 as i have al of them ?? also is the D16z6 head worth anymoney ?? thats another thing u can have if u want, please let m eknow this info asp as u always have so i can buy the items also is eagle rods and pistons good company ?
By KRYSTED9354
#42721
teal_dx wrote:you can get it bored .020 and use 75.5mm pistons. you can get vitara pistons for a good price.
local engine builders can do all the machine work & assembly
i do all of my work !!
KRYSTED9354 wrote:sorry not resistors just head retaners and valves and MABEY spring i dont think so also is it possibole for me to port my head my self ?? can i rent the equipment like at pepboys or ?? thanks and polease let mkenow if ur looking for anyparts or need anything for your help ? thank you so so very much i see what kind of wonderfull and great people or on this forum !
I wouldn't port the head yourself, could do more harm than good. something like that needs experience. Honda heads flow pretty good for being from the factory and porting them wrong can hurt. someone who knows what they are doing can increase the flow.
KRYSTED9354 wrote:also should i upgrade cam ? and throttel body ?
cam is a good upgrade, will help HP more than the other mods.. throttle body will improve initial response.
By KRYSTED9354
#42725 true but i seen people buy this kind of like bid oh should i describe it sander drill and get it oiled up and clean them out ?? or can the inside be drrenched overnight with something to get the build up out ?? also how can i CLEAN the a6 block up good ?? and the paint ?? and please answer my question before about the injectors+fuel rail and etc
KRYSTED9354 wrote:also should i use the injectors from the vx engine or from the d16a6 engine or the oney from the d16z6 as i have al of them ?? also is the D16z6 head worth anymoney ?? thats another thing u can have if u want, please let m eknow this info asp as u always have so i can buy the items also is eagle rods and pistons good company ?
I would use the injectors that match your harness. sonce you are using VX harness, use OBD1 injectors. I think vx and d16z6 injectors are the same. d16z6 heads are worthless I will give you $15 for yours j/k :D
A good complete d16z6 head might be worth around $100, a little more with the valve cover.
Eagle rods are a very good buy, I bought them and I've seen them take lots of abuse in boosted motors. As for pistons, go with vitara 75.5mm pistons. you can get a set for less than $100. they are cast not forged, but you shouldnt need forged pistons for a NA d16 build unless you plan on crazy compression. if you want to go forged then expect to spend $250+ on pistons
By KRYSTED9354
#42728 no do u want the d15z1 engine+head i will have as spair ? not the d16z6 head im using that :thumb:
ok now ANSWER ME SO IM SET TO GO ??? RIGHT ?? NOW UR NOT SO TELL ME WHAT U need or anyparts ur looking for ho knwos i have 2 shed full of honda shells and parts abey i got something ?? do u want a vtec sticker it will ad 2-5 horsepower ebay says so LOL LOL LOL :lol:
#42731 If I was closer I'd be on my way to pick up that D15z1 :thumb:
but I'm in OH lol.
I think you got everything but I'm about to fall asleep so maybe I'll remember something else tomorrow
By KRYSTED9354
#42738 rthanks were in ohio i go there once in a wile and can drop it off , im all over the place have 1 house in janesville,wisconsin and 1 in rockford,il
and come toward the ohio+indiana areas ok se ya later gater :lol:
By KRYSTED9354
#42812 ok these are the LAST questions for now intill i begin building ill also update pics as i go on ok ??
ok please answer these if u could in order, thanks u
1.what substance or with what can i clean the engine from the oil and stuff ?
2. should i drenche the pistons,valces,pins, etc in Z-MAx or what else and if ??
3.can i use the ecu of the delsol si d16z6 but its automatic ??
4.what do i have to do before i can paint the block and with wht kind of paint ?
5.what should i clean the cylinders,ports of head with what substance to get build up out if i wont bore it ??
6.any more tips on the build and things u remember ??
thanks
By KRYSTED9354
#42844 before u read this please answer the question above ,anywase can i use the p28 from an automatic car ?? also what is a cylinder spacer ?
KRYSTED9354 wrote:ok these are the LAST questions for now intill i begin building ill also update pics as i go on ok ??
degreaser or get it hot tanked at a shop
not sure about that
yeah but you'll have to take it apart & solder to convert it to manual
Degrease comletely, must be clean & oil free. Use engine enamel paint, duplicolor or VHT.
Mineral spirits
thanks
By KRYSTED9354
#42858 what to clean outiside of block with
By KRYSTED9354
#42866 ok great thanks u see i dont have the money to go and havew a shop port and plish it and tighty it all up , so i have a port kit and will be douing a test port on my beater si crx and see what happens any tips on when i clean the im or block or head or any tips not only for hp for for looks ?? any tips u got ill take them !!
By KRYSTED9354
#42867 oh also what city in ohio are u located OR more east or west because im going to be heading out to ohio next late month and can bring the z1 or if theres a part ud like ?
