- Tue Mar 04, 2008 7:02 pm
#44731
I had this problem as wel; you can hear the gear axle shout out, but it won't turn.
My problem was I moved my battery to the trunk, and put a 80A fuse between the connection I made in the engine bay and the cable to the starter... to much resistance from the fuse; it got 12v but not enough amps.
Maybe you should look into replacing the feed cable from your battery to the starter.
If that's not it, it's always a possibility your starter motor is dead or has a broken cable, as it is actually a two part thing; when one part gets juice, the axle comes out, but won't get the juice to the other half to turn to axle/gear round.
chrono404 wrote:I had similar Issues. it turned out to be the Main Fuel Relay.
On a USDM car its by the Fuse box, held on by a 10mm bolt. I bought 3 used ones over time and when one wouldn't work, swap to another one i had in the glove box. I finally bought one from Honda for 75.00 USD. I have not had a problem since.
You can easily repair your main fuel relay by opening it up and resolder everything.
That's free, you've just thrown 75 bucks away
